SteganoCC: Covert Channels for Android
SteganoCC is a set of programs that helps to experiment with covert channels between two Android colluding applications. Additionally, it also provides a way to collect energy measurements for all Android processes using a modified version of PowerTutor.
This project refers to the implementation of the results of the paper:
Other related papers:
News:
  • 07-07-2017 Added low-attention raising covert channels
  • 30-04-2017 Improved documentation
  • 14-06-2016 Release v1.1 has been uploaded
  • 02-05-2016 Source code is clonable !
  • 16-12-2015 Website is online :)
If you have troubles or questions write to jean-francois.lalande@insa-cvl.fr.
Repositories
The project is located at: https://gforge.inria.fr/projects/steganocc/
There are two repositories:
Howto for steganocc.git
L. Caviglione, M. Gaggero, J.-F. Lalande, W. Mazurczyk, and M. Urbanski, Seeing the Unseen: Revealing Mobile Malware Hidden Communications via Energy Consumption and Artificial Intelligence, IEEE Trans. Inf. Forensics Secur., vol. 11, no. 4, pp. 799–810, 2016.
Getting the code
Get the source code:
# Clone
git clone https://scm.gforge.inria.fr/anonscm/git/steganocc/steganocc.git
# Change to branch android-studio
git checkout android-studio
Open the project using Android Studio.
The git repository is an Android Studio project, containing multiple apps:
  • sender: the Covert Channel sender
  • receiver: the Cover Channel receiver
  • energyCollector: the Android service that receives the energy measurements from PowerTutor (via Intents)
  • powerTutor: the modified version of powerTutor that emits Intents containing the energy consumptions of all applications.
All the analysis of energy with IA methods is not provided here because it is done offline on a desktop computer (more convenient, even if it could have been performed on a smartphone). Thus, the IA code is not provided: only the covert channel implementation and the energy measurement is provided.
sender / receiver apps
The sender application enables to perform unique experiments with the receiver. By default, the receiver is always active, for all input methods.
First, you have to select the type of covert channels to use in the receiver ("Selected info" in the image below) and the synchronization method ("Select sync" in the image below). In the screenshot below, you see the "Volume settings - Music" method for the transmission and the "Content Observer" method for the synchronization. Other possible parameters are the time interval for sending data (the lower, the higher speed is obtained) and the number of time the experiment is repeated (test iteration).
Then, a message can be sent from the sender to the receiver hitting the "Send message" button and entering some text. Alternatively, an information from the phone (IMEI, contacts, etc.) can be send with the "Send phone state" button. In the receiver application, each received message is displayed. Details about one transmision results is reported (bit rate, accuracy, duration, etc.).
Sender and receiver have several options that can be used. Some of them are buggy or not implemented (in the receiver). The sender have several options to change the settings of covert channels. The Send after screen goes off button enables to start the transmission when the screen is switched off. The Listen for SMS enables to receive an SMS and start a covert channel transmission between the sender and the receiver with the received message contained in the SMS.
The scenario button is partially implemented (not sure it works !). It helps to execute several transmission implemented in a java code. New scenario can be found in the package com.steganomobile.common.sender.controller. In the current code, only scenario 1 is implemented.
analyser app
Not sure what is the purpose of the Analyzer app. It seems to be very similar to the sender app.
PowerTutor app
PowerTutor is a modified version of the original PowerTutor code that reports energy consumption to the EnergyCollector application. To begin collecting energy data, you have to start PowerTutor.
EnergyCollector app
The EnergyCollector application enables to automatize random transmissions of covert channels and to measure the energy. Thus, the implementation uses a service that waits some random time, then asks to the sender to perform a transmission to the receiver, and then repeats these steps. Parameters of the application are:
  • type of covert channels (Volume Music, Volume Ring, etc.)
  • the number of XP to perform
  • Activate the covert channel transmission or not (in order to make an XP with the same running code but without any transmission)
  • Email to use to send a notification when the XP is finished
All other applications are controlled using intents and the EnergyCollector code runs in a service.
In the image below on the right, you can see the logcat output filtered on the "JFL" tag. It shows an experiment with 2 messages with the setting "Volume Settings - Music". The experiment last 10 minutes. The main reason is that the 2 messages are sent at a random time during the total experiment duration. Thus, the more message you schedule to be sent, the longer the experiment is.
Description of Steganography methods
All the implemented methods are located in the com.steganomobile.lib.Methods package.
Volume Settings
Sequence of data is encoded into level of volume. With Music channel there is possibility to send four bits per iteration. Other channels have eight levels of volume, so we could send three bits per one iteration.
Type of Intent
Sender registers some intent actions and receiver sends data with appropriate action.
Unix Socket Discovery
Sending data through state of socket. Closed socket is equal to one, opened to zero. Closed socket is detected with Exceptions.
File Lock
Sender sends one by locking the file. Receiver also is trying to lock file. If he succeeded, he interprets action as zero. If he get en exception, it means that Sender has locked file before Receiver attempt. Action equals to one.|
File Existence
Similar to File Lock. In this case we are checking existence of shared file.
File Size
Sender sets size of shared file and Receiver interprets it as a byte.
Memory Load
Receiver gets initial memory load of Sender. Then Sender allocates data, and Receiver compares current memory load to initial state. Currently not working, cause GC does not deallocate memory, if we want to allocate less memory than we allocate in previous iteration.
System Load
Sender sends one by doing a lot of actions on CPU. Receiver check how many clock ticks Sender has got since previous iteration. If the usage is greater than border usage he interprets it as one. In the other case he interprets action as zero. Use time interval >= 200 [ms].
Usage Trend
Similar to System Load, but we are checking trend of measured usage. If usage increases - one. In other case - zero. Use time interval >= 200 [ms]
Method's research paper
Method Article Bit rate [b/s] Synchronous Detected ?-Based
Volume Settings 1, 2 450 Yes No Software
Type of Intent 1, 3 15000 Yes No Software
Unix Socket Discovery 1, 2, 3 100 Yes No Software
File Lock 2, 3 250 Yes No Software
File Existence * 250 Yes No Software
File Size * 2000 Yes No Software
Memory Load * 500 Yes No Hardware
System Load 1, 3 5 Yes No Hardware
Usage Trend 1 5 Yes No Hardware
[*] Method not used in previous papers
[1] Analysis of the communication between colluding applications on modern smartphones C. Marforio, H. Ritzdorf, A. Francillon, S. Capkun Proceedings of the 28th Annual Computer Security Applications Conference, 51-60
[2] Soundcomber: A Stealthy and Context- Aware Sound Trojan for Smartphones" R. Schlegel, K. Zhang, X. Zhou, M. Intwala, A. Kapadia, and X. Wang, , in Proceedings of Network and Distributed System Security Symposium, San Diego, USA: The Internet Society, Feb. 2011.
[3] Hiding Privacy Leaks in Android Applications Using Low-Attention Raising Covert Channels J.-F. Lalande, S. Wendzel
Howto for lowattentioncc.git
J.-F. Lalande and S. Wendzel, Hiding privacy leaks in Android applications using low-attention raising covert channels, in First International Workshop on Emerging Cyberthreats and Countermeasures, 2013, pp. 701–710.
Getting the code
# Clone
git clone https://scm.gforge.inria.fr/anonscm/git/steganocc/lowattentioncc.git
  • senderX: the Covert Channel sender, version X
  • receiverX: the Cover Channel receiver, version X
The difference between the 3 versions are explained later in this documentation.
The sender application enables to send a contact from the telephone. Thus, you have to add a contact to your phone. Then, the interface of the sender enables to choose which contact to send by the covert channels. The sender applications starts when the screen goes off. But before sending, you have to enable the receiver.
The receiver application displays the last character received. It also provide buttons to start/stop the service that receives the data. Start the receiver. You should observe some logs in the logcat window.
Return to the sender application and switch off the screen. The transmission should start.
You can observe, for example for sender2/receiver2, the following logs when transmitting "Gugu":
Receiver2's log:
starting listen service.
CCDC is gone
CCL: CCDC is gone
CCL: CCDC is gone
CCL: CCDC is gone
Then, from the sender2's side, when switching off the smartphone:
CCDCS: Scheduling priority 0 !
CCDCS: message to send: Gugu
CDCDS: sending character G at 0
CCDCS: Sending 6
CCDCS: Updating my priority to 4 !
My priority : 4 for TID=5347
Returning on the Receiver2's log:
CCL: I am monitoring process 5347
CCL: Screen is off, CCDC is there, and time is spending !
CCL: current potential info = 6 deltaT
CCL: CCDC has finished sending data (pid=5347)
CCL: RECEIVED: *** 5 ***
CCL: RECEIVED: *** F ***
CCL: CCDC is gone
CCL: I am searching the process with priority 4
Thus, you can observe that a F has been received which is almost a 'G'...
Now, the sender is waiting for the transmission of the next character "u" of Gugu (that is why is is written G < u > gu). If the screen goes off, the character "u" will be transmitted.
Versions of sender / receiver apps
Different versions are provided:
  • sender / receiver: it implements a transmission using the process detection (is the process still alive or not ?). Warning: this version should not work for new version of Android, greather than Marshmallow. Indeed, the listing of processes has been removed when using the GET_TASK permisison. A new permission exists (REAL_GET_TASK) but it is only used for system apps.
  • sender2 / receiver2: it implements a transmisison using the priority of processes. Each time the screen goes off, a character is sent by changing the priority of the sender process.
  • sender3 / receiver3: this transmission also use the priority of processes, but does not wait for the screen to goes off. Thus, it can be used to transmit at maximum speed a string.
For more details about the principles of these covert channels, please read the paper Hiding privacy leaks in Android applications using low-attention raising covert channels.
